94 convertible Airbag Light
hunts22
04-15-2005, 06:53 PM
The airbag light on this car will not go off. I've determined it is a code 12 but my mechanic is unsure of how to solve the problem. There isn't much info out there on this issue, any ideas would be great, thanks.
Quint94
08-07-2005, 08:49 PM
The problem is a Bad ground. You will have to remove the dash there is a common ground.
Cec
Cec
SikNingStang
08-21-2005, 10:58 PM
I have a 94 conv. with the same problem. It started when I got it back from get it painted. Take the dash off and there is a common ground... Where is the common ground? Do I have to take off the entire dash or maybe just the radio bezel?
GEOFFINKSTER
10-19-2005, 08:40 PM
How does a ground on the interior go bad , and under the dash . It just is hard to beleive. With my findings , I,ve replaced the clock switch in the sterring wheel. That is also the grounding point for the air bag light.
