Winter Mode
matemk
04-13-2005, 11:12 PM
Anyone with a 1992 Rodeo have the WINTER/POWER buttons working? if so how does it drive off the line in WINTER mode, does it do the same in DRIVE as it does in LOW?? does a WINTER light come on in the dash when activated? I need to know everything about it and possible then i can determine the problem in my car...i am thinking that if WINTER mode starts your transmission out in 3RD gear, then i might have the WINTER mode permenatly activated on my car, really sluggish off the line and doesnt seem to shift around when 1st gear should.
amigo-2k
04-13-2005, 11:17 PM
If you think the switch is hung up, pull it and unplug it. Take it for a drive.
on my 2000, I have to give is a lot of gas (2000 rpms) to start rolling.
matemk
04-13-2005, 11:39 PM
yeah, same problem as mine, about 2000 rpms to get going, a little while to get up to about 10 mph, i have tried unplugging it, and just moved the car around in the drive way, maybe about 5 or 10 ft, cant go too far with it right now, any way to figure out why it is stuck, or if it is even that? i have already pulled the switch apart and put it back together with no luck
doommarine44
06-21-2005, 11:13 AM
Im not sure if thats what winter mode does, but mines not working, and my isuzu is stuck in 3rd gear while in drive.. also has a check trans light on.. If i drop it to L it goes to 1st, etc. etc..
D-FOSSE
06-26-2005, 08:43 PM
winter is made to give you mor tracktion (a lower gear) you have to be stop to put it in and no a light does not come on and after you hit 25mph it shuts off so it is made to go sluggish and slow i use my when im mud ridding
