leaking oil/blowing seal
KPot2004
04-13-2005, 08:22 PM
after 4 or 5 minutes of running for some reason my front seal under the timing chain starts leaking oil, this is really starting to piss me off since i just got it back together. The first time it leaked i figured i screwed up so i replaced all new gaskets on the front of the engine. well this time it ran fine for about 5 minutes then it started leaking again
any ideas?????????
wrightz28
04-14-2005, 12:55 PM
Are you sure you're putting the crankshaft seal in the right way? Lip only goes in one direction. Also, when you put the balancer/crank pulley back in, you need to put some oil on it otherwise it can tear the seal when being installed.
Hypsi87
04-14-2005, 01:08 PM
maybe a bent crank?? hope not! if you have a dial indacator, you could check for shaft run out.
Savage Messiah
04-14-2005, 01:37 PM
Simple thing but is everything tightened to spec and not stripping?
KPot2004
04-14-2005, 04:21 PM
could it some how be built up pressure in crankcase, the other day when I had it running the oil cap was getting blown off, it seems to me its not venting very good. could this be the problem???
And on a side not these chrome valve covers i bought have a god damn baffle right where u pour oil in, when i put oil in it it took me seriously about 20 minutes
wrightz28
04-14-2005, 04:25 PM
Do you have a PCV valve?
KPot2004
04-14-2005, 04:34 PM
yes
wrightz28
04-15-2005, 08:37 AM
It's or the hoses are not clogged?
Xenostalgia
04-15-2005, 09:13 AM
Its gremlins I say... Gremlins!!!
KPot2004
04-15-2005, 09:38 AM
you shrunk your sig!!!
philly rs
04-15-2005, 10:24 AM
it blew the damn cap off?? thats alot of pressure buid up, glad u werent standing next to it when it blew
