will they fit?
whoisdabomb86
04-11-2005, 09:37 PM
i oredered bf goodrich radial t/a my back tires are going to be 275/50/r15 will these fit. the spacing on them is 11 X 26" i got the 50 series cuz there lower profile. im afraid of the wheel well in front of the wheel cutting in too far and its gonna rub. anyone put this size on their rims? i ordered black rims btw im gonna turn the letters out, i think itll look sick with the black car.
whoisdabomb86
04-12-2005, 10:33 PM
cmon guys someones gotta know if 11" tires will fit on a third gen camaro, and will i need to use wheel spacers pleese help thanks in advance
joe
J.Cutta
04-12-2005, 11:31 PM
I believe I can help. I was in this same situation you are in. I wanted white letter tires but stock size 245/50/R16 would not carry them in that size mainly because a 50 series tire would be weaken too much because of the letters raised in the side. 70 series tires usually go big cars like a caprice. In all they might fit if you have a 14 size rim at the most anything over that would not fit and if it did it would make the car sit higher and look very odd not to mention you probably wouldn't be able to turn. If you really want white letter tires spend 800 on some nascar tires
Genopsyde
04-13-2005, 12:03 AM
i'm sure they'll fit just fine, i've seen wider on a third gen before.
whoisdabomb86
04-13-2005, 12:16 AM
my question is how can a major tire complany like bf goodrich make a 50 series and have them not be stable. these will be going on none other than a 15" rim true muscle car styling. they have an overall diamter of 29.9 inches. im afraid of them hittin on the front part of the fender. they shouldnt sit too much higher than the tire i had which was a 235/60/r15 im putting a 235/60/r15 on the front. the guy from summit said the 235 is as high as that 275. do u think wheel spacers are ok to use, and whats involved like longer studs? that front part of the inner fender cuts in awfully close.
