no spark or fuel???
bhough03
04-10-2005, 05:23 PM
not sure what the problem is but the car will turn over but has no spark and no fuel will go through the injectors. changed the distributor, plugs, and wires, and still no spark. changed the fuel rail, injectors, and engine harness, and still no fuel. crank censor however isnt getting any power. thought possibly the pcm or ecu. any ideas??
ZX2000
04-12-2005, 06:56 AM
i'd guess you're right w/ the pcm. also, the zx2 is distributorless. you replaced the coilpack.
Justin3339
04-13-2005, 02:44 PM
I have the same problem. I switched engines and now I have no spark. It turns over and has compression but no spark. I bought new coils, a new camshaft position sensor, crankshaft position sensor, and even got a different pcm. Still nothing. I am scarred that I might have to get a new wiring harness or ecm. If anyone has any idea what I need please help. Oh yeah how do you test to see if the PCM is bad? It is the little box under the air filter right?
