What is this?
Mayday0017
04-09-2005, 08:56 PM
The bracket that the ignitor chip comes con has 2 other pieces on it. seen in this pic http://i22.ebayimg.com/03/i/03/c9/bc/e6_1_b.JPG While I was removing stuff from my engine bay this weekend to paint it I decided I would be curious and figure out what the other two pieces on the bracket are. I have them on there still ust capped the vacume lines on the one and such.
J SPEC SilEighty
04-10-2005, 02:15 PM
It's just another wastegate control solenoid. The MAFS voltage tells the ecu how much air is flowing across it, you don't need the wastegate control solenoid. Air flow is a better measurement than psi, which would be inferred air flow. Most people I know don't run this, they just cap it off like you did.
Mayday0017
04-10-2005, 04:52 PM
do I need to plug it into the engine harness though? ALso what is the thing below the ignitor chip?
