how much would something like this cost?
EVOclipse
04-09-2005, 12:56 AM
" The motor will need a new crankshaft, the guys that put in my new clutch and flywheel didnt torque the bolts down all the way and as soon as I turned the boost up it broke the flywheel right off the crankshaft"
thats what im looking at getting and i was wondering about how much would a repair part+labor on this kinda engine/car would this cost me? and does it sound fishy or what?thanks
DWF Engineering
04-09-2005, 01:07 AM
Well, you should be able to get a used engine from a salvage yard for less than $500 and install it yourself in a couple of days. Assuming you have the know-how, tools, and a hoist. I'm just guessing it to be a 10-15 hour job and guessing again, the shop rate is like 50/hour. $900-1300 would not be absurd for a used engine install.
I stated in another post that I replaced my manual gearbox recently. Before I did it I called around to some different shops to see what they would charge to install a new or reconditioned gearbox. The lowest I found on that was $3900 for all parts and labor. I put a used one in myself and it cost $300 + tax + $100 core charge. Total expense was like $320. Fix it yourself; its cheaper unless you could be doing something else with your time that pays more than $50/hr.
Unless I've got lots of money and/or I'm a good mechanic/tuner/body-man/etc. I'm not going to buy a car that needs a lot of work right from the get-go.
nissanfanatic
04-09-2005, 01:15 AM
Sounds fishy to me. I'd pull it apart and inspect myself before spending any money. What engine is this on anyways? What car? Info please...
sidewayzS13
04-09-2005, 01:17 AM
so you need a new tranny not a new engine? am i correct?
DWF Engineering
04-09-2005, 01:29 AM
Hopefully we're talking about an S13, S14 or S15. If we're talking about an Eclipse, I still welcome questions, opinions and offer advice, but we're in the wrong forum and seeing that I have no eclipse to tinker with my knowledge in this field is limited.
EVOclipse
04-09-2005, 09:09 AM
sorry i forgot i cut that part out of the post, its an 89 240sx with the CAengine in it from the 180sx.and the reason im asking is because i got so frustrated just trying to do the headgasket on my car(eclipse) because chrysler puts shit together all kinds of fucked up.the labor hours is like 10-11 for a damn gasket,and no i dont have all the tools to do it myself. the headgasket was pushin my limits and it didnt need the hoist and all that =P
nissanfanatic
04-09-2005, 04:14 PM
Headgaskets on most cars are a day job at least. Just be glad you don't have a V type engine.lol
Why do you think you need a new crankshaft if that did happen? The bolts are probably what broke. Flywheels are pretty tough in general from the factory. You'll probably just have to do a little tinkering to get the broken off bolts out.
