KA-T setup
november-ice
04-08-2005, 05:52 PM
was looking in to a turbo setup and was wondering how this one stacks up
total priced ship like $4300
T3/T4 .48 ar stage 3 wheel turbine .50 ar compressor 50 or 57 trim
Flow bench designed and tested tubular stainless steel manifold
3" flowbench tested downpipe w/ o2 sensor bung installed
38mm External Wastegate
2.25" Stainless Steel Intercooler Charge Pipes (Short Routed)
Custom built intercooler w/ extruded Garrett Core 24" X 6" x 2.75"
25mm Recirculating Blow off Valve or 35mm Atmospheric
Stainless Oil Feed, Return, fittings and weld-on bung for oil pan
Air Intake Filter w/ z32 Maf + Adapter
All Silicone Boots
GReddy top-feed fuel rail
RC Engineering 52lb injectors
RC Engineering clips for injectors
Aeroquip fuel feed and return lines and fittings
Fuel pressure regulator
Walbro 255lph fuel pump
Clutch Specialities 6-puck Stage 3 clutch w/ sprung center, dual pressure plate diaphragm, throwout bearing and pilot bushing and alignment tool. It is good for 550 ft.lbs of torque
Factory rods shotpeened and balanced good for 450 rwhp
9:1 forged pistons with rings, wrist pins and clips
E-manage w/injector and timing harnesses
Greddy Turbo Timer
any thing im mising or should add?
All Silicone Boots
Greddy Turbo Timer
s13dr1fter
04-08-2005, 07:34 PM
That looks alot like the Boostdesigns stage 3 turbo kit.
orestes
04-08-2005, 07:35 PM
i dont think you need a stage 3 clutch
sidewayzS13
04-08-2005, 07:41 PM
boost desings kit id cheaper though i think you would be better off just going w/ boost designsbut its ur car and money
DWF Engineering
04-08-2005, 07:45 PM
All that for $4300 is a good deal for a package! I think the TurboXS kit is $4500 and doesn't include nearly as much. I think its a T3/T4 as well. Maybe a regular T4 though. Its just a bolt on kit though. Man, $4300 for all that and a bag of chips...You'd be in Heaven.
But unless you're building a race car or street legal super car you are just as well off to source the parts individually whenever you see good deals on them and build a stock-block KA-T for $1000-$1500. As for the fancy clutch: your tires will slip long before the clutch will. I'm still naturally aspirated and easily run out of traction in first and second gears on most public road surfaces; drag strips and curcuits are made from special asphault to improve traction so I don't have a problem there but with the power outputs you could be making on the parts you mentioned...I'm wondering how you're going to make it bite the ground in your lower gears. You might want to think about the 300ZX limited slip differential; its a higher gear ratio so you wouldn't break loose quite as easily. The bad thing about that though is that with a higher final drive you'll have even more trouble finding traction if you do accidently break loose.
Bottom line is that you'll need to spend another $4300 on suspension, wide & sticky wheels/tires, and custom fender flaring to ever make use of the power. Then you'd have your race car or street legal super car.
sidewayzS13
04-08-2005, 07:49 PM
u cant have a set up like that w/o some suspension and brake upgrades
november-ice
04-08-2005, 08:35 PM
for the most part is it the Boostdesigns kit with a
minre change..
my plans are to get a junkyard pulled ka and rebuild it with the kit paint and powder coat the block
then swap it.
i was looking in to the greddy stage 1 kit but they wanted 2.6k at some cheap site and greddys site wanted 3.6k and that was 370cc inj with out a intercooler
al tho i dont know the quality of those injeters
so i may go VENOM injs and rails
i seen posting on here saying i should be able to get the block for about 300 to 600 with trany?
but over all i just wanted to see if the kit/parts were worth it
thanks
minre change..
then swap it.
thanks
november-ice
04-08-2005, 08:47 PM
im in vegas an id love to see some track time since its like 40 min away and they got i think a 2mile
course about an hour 1/2 away
but mostly i just like driving around like 3am
but im looking at maybe a year 1/2 befor i can do that kind of power swap
im used to having no suspension suport atm im driving a grand prix, was going to fast one night
and took a sharp corner at 50+ almost felt like
lost the front end haha
but what do you sugest?
i herd good things about TEIN
JDMTYTE 240 YO!!!
04-08-2005, 10:29 PM
Skip the E-manage. Its not much cheaper than a tuned ECU plus it requires a laptop. Its a big, fancy, wanna-be standalone, but still a piggyback that does the old fashioned alter MAFS voltage trick. SAFC+BTM will get you the same deal. Just use the money plus a tiny bit extra and get a tuned ECU from either JWT or enthalpy as boostdesigns sells them for #50 injectors. Up side is no tuning is required.
And get a wideband O2 sensor. Best investment there is.
november-ice
04-08-2005, 10:35 PM
ya they sell the s14 tuned ecu for 600
nissanfanatic
04-08-2005, 10:41 PM
Its worth it. Trust me. Its really nice to have your fuel and timing maps taken care of instead of "Altered".
sidewayzS13
04-08-2005, 10:43 PM
tein is good but hit and run will tell u its overpriced for what yur getting
november-ice
04-08-2005, 10:51 PM
i like the ..i thnk it was 5 pesetable controls from the driver seat
its not to fun to keep adjusting them for difrent conditions
is there a brand you recomend
and those CF door panels look nice but i would of liked to see a little moding done to them
then again im just mad i can find kick panel speaker
setups........
setups........
