accord turn signals
badassaccordriver
04-07-2005, 09:28 PM
Just got done installing a set of Depo JDM style headlights on my 5th gen accord, headlights work great and look real nice. The only problem is that the stock Accord corners have two holes, one for the running lights, and one for the turn signals. The Depos only have one hole that only the running light socket plugs into. Can anyone tell me how to wire (if its possible) my turn signal wires to my running light wires so the bulbs will have a dual-fuction running lights/turn signals? Pretty experienced with wiring, and it looks relatively easy to do (both the running lights and turn signals just have a red and black wire coming off each one), just need to know if splicing the turn signal lights into the running lights will work. Thanks.
94hondaacc
04-08-2005, 12:28 PM
yeah it will . all you have to do is cut off the wiring that goes to the turn signal socket. connect this wiring to the socket for the running lights. black tape the wiring from the running light, since this wont be used anymore. and viola, your done. hondas are great to do this with cause the light say on with the lights and then blink when you turn . good luck
