this is going to sound stupid
mrgofast21018
04-07-2005, 12:45 PM
this is going to sound extremely stupid. i was just thinking tho. i seriously was in the shower and lightning struck. i dunno if this idea has been proposed or anything. i think its crazy and noone can produce them in mass so its not going to happen.and i had no idea where to put this so i just came here cuz fourth gens are the best. imagine if anyone ever created an engine with these specs.
its an all aluminum v8.
double overhead cams on both banks.
direct injection. (higher compression ratio with turbos)
add supra twin turbos to both sides so you get no lagg whatesoever.
make it have vtec.
and make it dry sump.
with hemispherical heads
match that to a seven speed tranny.
and an all wheel drive system
with fully independent suspension on all four corners.
jeezus christ if someone built this.... it would destroy everyother thing out there. period.
i was just dreamin. thank you for indulging me :tongue:
make it have vtec.
clawhammer
04-07-2005, 12:56 PM
Well, go for it. I would order one from you if you successfully built one. You could probably rev it up to about 8k, run a huge amount of boost, and get less than 10 mpg(arm and a leg)
mrgofast21018
04-07-2005, 01:01 PM
i have no clue how i would even start something like that. it would be like putting a vtec head and a hemi head in a room and letting them make love.
Gohan Ryu
04-07-2005, 01:13 PM
I think all that would happen is a lot of head.
Ones&zeros
04-07-2005, 03:27 PM
Sound Like You Need To Visit The Salt Flats Aka Boneville. Its An All Out Race For Top Speed.
89si
04-07-2005, 04:27 PM
being in the shower when lightning strikes is indeed stupid.
mrceej
04-08-2005, 09:58 AM
http://www.weblogsinc.com/common/images/9647767121144188.JPG?0.6210753072307975
http://www.pungas.com/galerija/albums/userpics/10008/lm1.jpg
http://www.pungas.com/galerija/albums/userpics/10008/lm2.jpg
http://www.pungas.com/galerija/albums/userpics/10008/lm3.jpg
http://www.pungas.com/galerija/albums/userpics/10008/lm4.jpg
Layout: 90 degree V8 Naturally Aspirated
Displacement: 4000cc
Horsepower: 590hp / 9500rpm
torque: 383lb/ft / 7500rpm
Restrictor: 33.4mm x2 or 46.8mm x1
Clutch: Carbon 4 plate
length: 559mm
width: 720mm
height: 577mm
weight: 131kg
Not exactly what you are looking for, but is it good enough for now? :rofl:
length: 559mm
width: 720mm
height: 577mm
weight: 131kg
CBURKE
04-08-2005, 10:06 AM
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA no not in a honda nooooooo.
the point of the honda is that we make a hole lot of shit out of nothing. If we put in a v8 then you might as well just call us a ford or chevy and then they would never talk shit to us. Screw that give me my 4 banger and let's get started!!!
mrgofast21018
04-08-2005, 06:43 PM
a v8 in a honda ehh? sounds like a plan to me. lets build it now.
aftershock192
04-16-2005, 12:16 AM
lets make your dream a little easier. take a ford 5.4 liter v8 block overbore it. Drop in a 4.6 liter crank and the late 90's svt dohc heads. lengthen the con. rod and slap on two gt25r71>(maybe a little bigger) and your talking 700+ horsepower and a very sweet powerband.
Its just a dream motor i wish i could afford
Onimacus
04-16-2005, 05:40 AM
I'll take a b20vtec please :) thats the only motor i dream about.
CBURKE
04-16-2005, 07:36 AM
Yeah, the only motor I wanna see has a BIG RED v-cover with Vtec on it an it came from a Type-R in my civic.
doug294
04-16-2005, 09:55 AM
Your telling me. I would love to have B20/vtec/turbo.... drool.
I have wished time and time again that my honda motor would fit into my eclipse. That would be awesome.
CBURKE
04-16-2005, 10:38 AM
umm wait, eclipse turbo? if so hell no i would not want a honda motor in there. My mitsu has not lost to a honda yet. opps sorry i just saw you sig. If you need any help on that turbo stuff let me know.
doug294
04-16-2005, 10:46 AM
Yeah if I had a turbo eclipse no way. I still can't decide if I want to go turbo with it or keep it as a daily dirver. With all the stuff put into my civic I don't want to rack up a bunch of miles on a built motor. Plus my eclipse gets better gas mileage.
Hybrid1990crx
04-16-2005, 02:57 PM
i'll take the v8 and use it for a daily driver. bang your mom and 2nd at the same time.
90civicracer
04-16-2005, 04:50 PM
Don't turbo you're '96 Eclipse. My friend had a '96 RS Eclipse (same engine as gs, 420a) and tried to put the Hahn Racecraft stage 1 (i believe) turbo set up and had nothing but problems.
doug294
04-17-2005, 10:32 AM
Theres his first problem, the Hahn stage one kit doesn't even have an intercooler which is a big no no. Second if he used the FMU that was a second mistake. If I do it I will probably make my own kit. $3k for a turbo kit...no way. And the parts they use are not even that good of parts.
