95 Formula:Steering Loose
FormulaForce
04-06-2005, 01:44 PM
My 95 Formula has developed some really bad play in the steering. It is difficult to keep it in a straight line especially on the highway. The steering wheel has almost 1 inch of loose play each way. A mechanic replaced both tie rod ends and re-aligned it, but that did not help. Everything else he could see looked o.k. Could it be the rack itself? Advice please.....
Hypsi87
04-06-2005, 02:35 PM
sounds like ball joints. or bad wheel bearings
FormulaLT1
04-06-2005, 02:49 PM
your steering linkage most likely came loose. Its a commen problem on LT1 F-body's. If you look at your linkage just to right of your exhaust manifold on the drive side you will see a bolt. If you take out your airbag fuse loosen that bolt but don't take it out the whole way. Then with a hammer tap the linkage towards the firewall. til all play is removed. That should do the trick. Good luck.
John
FormulaForce
04-08-2005, 01:03 PM
Thanks for the info. I will check it out.
