Wipers: Winter/Summer?
Doc_Ratchet
04-05-2005, 04:04 PM
OK, I've seen a couple posts about a winter/summer switch for the windshield wipers. Where exactly is this positioning switch located and how do I switch it over? This has got to be the silliest question I've ever had! :p
Doc_Ratchet
04-05-2005, 04:06 PM
It's on a 91 Probe GL if that helps any.
shawnwilliams
04-07-2005, 01:16 PM
By you fuse box i belive, you might want to check your manual, it will tell you exactly were it is.
Doc_Ratchet
04-14-2005, 03:06 AM
Unfortunately, I don't have an owner's manual for either of my Probes, but I do have a Haynes manual. Looked through the index for it and came up zilch. Probably just have to read all the chapters on wipers. Oh well.
shawnwilliams
04-14-2005, 01:02 PM
i'm about 90% sure that its by the fuse box, or under the sterring wheel. Oh i think its in the fuse box, look for a little switch inside, i think its there.
risingernicole
04-16-2005, 11:03 AM
In my 91 LX, it is next to the fuse box below the steering wheel. It is a connector not a switch. Lower is summer and upper is winter. You just gotta disconnect it and put it into the other one whichever you want.
