HELP locked in ,can't get out
mrbad
04-05-2005, 01:39 PM
I've replaced the DS door handle an a 92, 2dr, GP se, no problem to fix .I, myself tested the new handle 6x at least. my wife tries to enter the dr,door and it will not work. I believe it is the short little rod that connects the outside & inside handle to the latch has disconnected itself, Is there a way to get to the latch w/o destroying to much of the interior panel ? any idea's would be much help thanks
vamc
04-06-2005, 11:20 PM
i think its that little rod to. that is a common prob, that damn handle. if worse comes to worse, weld it.
carnutcass
04-07-2005, 08:06 AM
Pull the door panel and check it out.
