Rough horsepower estimate please
Mayday0017
04-05-2005, 11:54 AM
I have Red top Sr20det, Blitz Nur (3.5") exhaust with matching test pipe, Upgraded fuel pump and 300zx filter, Greddy hot pipe, stock boost and stock IC.
I am about to add FMIC trying to figure what my hp will be then also, so all of that plus going to turn my Profec B on and turn the boost up around 14psi with 3" greddy hot and 3" greddy cold and with blitz BOV. What kind of hp should I be seeing then?
TatII
04-05-2005, 12:43 PM
with all that, on average you should be lookin at 220-230whp. if your lucky and got a freak like rednecks, or mynismos then you'll be in the 250whp range.
mynismo
04-05-2005, 04:51 PM
hah...
see above post :)
see above post :)
nissanfanatic
04-05-2005, 05:21 PM
Whats with the 3" charge pipes?
turbo2nr
04-05-2005, 05:39 PM
what the size of the down pipe going into the test pipe and exhaut? but like every1 said about 220whp that being on the low side..
im assuming the charge pipe is the i/c piping..
1
1
nissanfanatic
04-05-2005, 07:10 PM
Yea.
I would also like to know the size of your downpipe. IDK what exact HP I picked up from going from a 2.5" wrinkle bend& crush bend downpipe to a 3" mandrel, but I know that my car now has a noticable pull in 5th gear. Even at 110, it can pull to the limiter with ease.
Mayday0017
04-05-2005, 10:26 PM
I don't know if my downpipe is 3" or 3.5" honestly but it is one of the two.
DWF Engineering
04-08-2005, 05:57 PM
I think your power now should be something like 235 SAE net hp. Thats at the output shaft of the transmission so your WHP should be about 225.
FMIC: 235 WHP
14 PSI: 300 WHP is possible if your turbo is upgraded to flow just as efficiently as it did when boost was limited to 7 psi
FMIC: 235 WHP
nissanfanatic
04-08-2005, 11:12 PM
No point in bragging about anything that isn't making it to the ground.
Its common knowledge that most "Stage 1" SRs(filter, downpipe, exhaust, FMIC, boost controller) lay down about 250whp-270whp. STock turbo maxxes out at about 270whp. Boost means nothing without flow so a larger turbo would be a beneficiary mod. Should look into a larger MAFS and injectors when you get to 250whp as they will both max out in that area.
sidewayzS13
04-08-2005, 11:16 PM
250-270 at whhat boost?
240SXSlideStar
04-08-2005, 11:38 PM
14, I think.
