Hazard Button
jalfaro
04-01-2002, 11:59 AM
The light on my hazard button seems to turn off when it wants to and when I tap on the button it comes back on. What can I check inorder for it to say on.
rfsee
04-05-2002, 10:28 PM
sound like a loose connection. probably at the switch. you could pull the center console apart and check it out and the bulb that lights it.
have you or anyone had trouble with the hazzard light sticking? I've had the one on my 96 ex stick in the pushed in position then it's impossible to get it to pop backout. it seem to be worse in the winter when it's cold. interestingly i had the same problem with my 86 prelude's hazzard swich. i find it so annoying that i'd like to change the switch to a rocker. has anyone done this or had this problem?
