What gear do i have?
kdc2003
04-04-2005, 08:23 AM
how do i find out what gear is in my 97 gt?
i know that i could take the rear apart and count it, but i also heard about a way where you count the number of times the wheel and the drive shaft turns.
i was wondering if i could have the numbers of turns or where i could find them.
HiFlow5 0
04-04-2005, 10:05 AM
There should be a door tag on the drivers side door, near the striker. Look for an AX code.
kdc2003
04-04-2005, 10:47 AM
i bought the car used and i think there might be a gear in it, so i was looking for a way to find out if there is a gear and what gear it is. the reason i think there is a gear is because the speedo is not accurate.
SkylineUSA
04-04-2005, 10:56 AM
Lift the car's rear, and count the times your drive shaft turns with one revolution of your tire. Put it neutral of course.
GTStang
04-04-2005, 01:45 PM
Real man pulls the diff cover and counts the teeth!!!! J/K
SkylineUSA
04-04-2005, 01:54 PM
I am lazy bastard :D
HiFlow5 0
04-04-2005, 11:16 PM
So that wouldn't be you then! :biggrin:
GTStang
04-04-2005, 11:43 PM
:iceslolan
kdc2003
04-08-2005, 02:00 PM
ok i turned the wheel once around and the drive shaft went around 3 and 3/4 times. what does that mean? Is that all i need to figure out what gear it is?
SkylineUSA
04-08-2005, 05:04 PM
3.73s
