00 accord LX coupe aceleration
CuN-
04-02-2005, 12:44 AM
i own a 2000 accord LX coupe 5 speed. for some reason it takes forever to pick up speed even if i push the gas all the way down...Anyone have any idea what it could be and what i could do to make it acell faster?
Igovert500
04-02-2005, 01:34 PM
Well how many miles do you have...you may need a tune-up
check the airfilter, spark plugs, air pressure in tires, start with the basics.
CuN-
04-02-2005, 02:07 PM
i have 91,000 miles on it
Igovert500
04-02-2005, 02:34 PM
Have you had a full tuneup done on it...because it's about time.
CuN-
04-02-2005, 05:08 PM
no i have not had a tuneup done to it about how much am i looking at for a full tune up on it?
Igovert500
04-02-2005, 07:32 PM
Well that really depends. Parts will probably only be a few hundred, but the labor is what may get expensive. Dealerships charge 55-70 an hour. If you have a private mechanic you trust, you may get it done cheaper. So basically it will range from $400-$800 I would guesstimate. Someone else may be able to give you a more exact number.
alizezaccord
05-02-2005, 04:26 PM
Check your exhaust system also,espicially your cat. Yea u need to jump on the tune up thing.
