diagnostic
tcfco2005
03-30-2005, 06:12 PM
my check engine light has been coming on for a few weeks now so i finally decided to check it out. it returned to me two codes. one was code 32 wich is the differential pressure sensor. and the other was code 54 wich is mixture control solenoid.And all i have is a book that tells me what the codes are but not how to fix it. So does anyone know how to fix these problems
my car is a 91 rs with a 305tbi auto
ridge_runner
03-30-2005, 07:08 PM
ummm maybe your diff fluid is low... try deleting the codes and reseting the computer and see if the mix control sol pops back up
DaMoNe6969
03-31-2005, 09:10 PM
Not to be a nag or anything, But they've started a "problem diagnosis" forum some time ago for questions like this
anyways, you've got your codes mixed up.. I really don think camaros have a differential pressure sensor (could be wrong?)
Code 32 Is an EGR sensor circuit fault.. Either your EGR valve is plugged up (very common) or the EGR solonoid has gone bad..
Code 54 is a Fuel pump/ECM circuit fault..
I'll try to find my manuals to get you a little more info on the code 54
