Siezed...
Thourun
03-30-2005, 03:53 PM
Ok well I decided to change all the oil in my car today, went fine till I tried to get the transfer case fill plug off... Its siezed to hell, I tried a wrench and sledge but its hard to hit it with any force while squezed under the car (need to get a better jack than the stock one, dosent lift the car enough). Should I try heating it up with a blow torch? Thats the only option I can think of now. Tried PB blaster and got eyed by an errant chicken that didnt like me... Ohh and like an idiot I drained the transfer case fluid first.
Linebckr49
03-30-2005, 04:42 PM
pb blaster or whatever rust penetrant. spray it, let it sit for a few hours, and spray it again. when removing the plug, i've found that if you use a 1/2" drive ratchet, you can put your foot against the ratchet and push slowly yet firmly. that should do the trick.
Thourun
03-30-2005, 06:50 PM
I can't get a rachet in there since the O2 sensor is in the way and I can't get that off either lol! I think I'll try the torch... gotta make shure to wipe off all of the gunk or it might catch fire.. that would be bad!
talskinyguy
03-30-2005, 11:11 PM
umm, are you sure your loosening the right bolt, you should just be able to put a wrench on it and smack it with your hand a couple times.
Stealthee
03-30-2005, 11:16 PM
You turning it the right way? Sorry had to ask. :p Definitely get ahold of a better jack, and find some sort of cheater pipe if it still wont break loose.
Thourun
03-31-2005, 12:03 AM
Yes its the right bolt, its in a different (much harder) place on the 6 speed. And yes I'm doing it the right way lol I stopped to think about that a million times.
6 Speed
http://www.stealth316.com/images/tc-6spd2df.jpg
5 Speed
http://www.stealth316.com/images/adf-manpage2.gif
Notice its on the front of the transfer case in the 5 and on the drivers side right next to the downpipe on the 6.
6 Speed
5 Speed
aking3000gt
03-31-2005, 12:07 AM
you could always pump the fluid in the tc.... from where you pulled the drain plug into... i had to do it that way when i changed fluid in my rear diff
Thourun
03-31-2005, 12:16 AM
I kinda want to do it right, Dampachi might be coming over tomorrow to help get it off lol.
