First Gear Pops Out
SunTzu310
03-30-2005, 02:01 PM
I'm not sure if this is normal. Others I spoke to told me it happened to them, but went away after a while. It hasn't gone away in my case.
I have a 1998 Toyota Tacoma v6 4x4 Xtra Cab 5 speed. Sometimes when I am in first gear, as I acclerate, the gear pops out of gear. If my hand isn't there, it makes a loud sound. I've tried to fix it by replacing the bushing and the rubber washer (the one that sits underneath the stick shift). It stopped popping out for about a week, but then continued to do this.
Anyone familiar with this problem?
Shredhead
03-30-2005, 06:03 PM
I had a problem with 3rd and 5th doing that on my 93 2wd I replaced the clutch and transmission fluid and it went back to normal.
truckpoor
03-30-2005, 10:25 PM
possibly the synchronizers in the tranny
SunTzu310
04-06-2005, 04:23 PM
i figured other's had this problem...but I guess not...are you sure it isn't anything else, cuz i swear it doesn't seem like an uncommon problem with people I nkow, but no one has ever given me a solid answer.
Flash75
04-06-2005, 08:28 PM
Worn shifter forks or bent shifter rails are probably causing it to pop out.
Clifton
Clifton
Flash75
Clifton
Clifton
