Starting Problem
BCannella
03-28-2005, 11:18 AM
I have a 89 F-250. One day it just doesn't start, all I heard was a click everytime I turned the key. I replaced the Selenoid, Starter, Battery, and Ignition Switch. Now when I turn the key it sounds like it starts but as soon as I let go of the key it stops. I was told that it could be the Ignition Control Module but I checked for "spark" and I have spark. So I don't think it could be ICM, Coil, or Distributer. Not sure where to go from here.
Bryan
gbic1
05-04-2005, 10:56 AM
Try turning your key on and jumping solinoid to see if you have spark then. Your module has two circuits run and start. You may have lost your run circuit.
