suspension install
afaccord
03-26-2005, 04:14 AM
I just bought skunk2 coilovers and tokico ill shocks for my 99 accord. I am having trouble because many mechanics won't touch it because it has been dropped 2in. I am thinking of doing the install myself but am afraid the drop could cause some problems. Would i need any special tools for the install? I also just bought the car used and i am not sure if it already has a camber kit, would it be alright to use the old camber kit if installed? If not, is it imperative to buy an expensive kit?
sivic02
03-27-2005, 11:58 AM
Im not a big suspension guru but I think you should be able to reuse the camber kit if it has one, and I think it should since it already has a 2in drop. I think the only thing you might need for the install would be a spring compressor. That and after your done make sure you take it down to an alignment shop.
Ones&zeros
04-07-2005, 05:10 PM
Im not a big suspension guru but I think you should be able to reuse the camber kit if it has one, and I think it should since it already has a 2in drop. I think the only thing you might need for the install would be a spring compressor. That and after your done make sure you take it down to an alignment shop.WHAT HE SAID
