spark plugs and wires...
Kidlex01
03-25-2005, 12:01 PM
Im curious about changing the spark plugs and wires someone told me to go with NGK IRIDIUM XIII and some MSD 8mm Wires, First how do you loacte the spark plugs and change them second, What are the benefits of chaging the plugs and wires to a premium plug?
Ridenour
03-25-2005, 12:27 PM
You have a 3.4 I'm assuming? If so, I have a set of MSD 8mm wires and NGK Iridiums, and love them. The location of the plugs is 3 on the front, 3 on the back. I don't understand what you mean by "locating" them. Just follow the wires from your coil packs and they lead right to the plugs. And you ask about the benefits of changing to a "premium" plug - are you referring to the iridiums? Changing to the NGK Iridium helps out a little because the plugs run cooler then stock plugs, and produce a stronger, larger spark, exposiing more of the gasonline/air mixture to the flame front. A stronger / cleaner spark = quicker combustion.
Kidlex01
03-25-2005, 12:33 PM
yah sorry i didnt mention it i have a 2.4L ...
