Engine Code Spark
Ogami
03-24-2005, 06:54 PM
Hello everyone, been awhile since I've posted been very busy with school and work. I've a recent series of events happen with my talon. A couple of weeks ago my shifter cable snapped, no big deal got it towed to my transmission guy. Fixed it within two days, picked it up and noticed that my check engine light was on again after finally replacing the O2 sensor last month. Also noticed that my steering wheel was about a quater of the way turned right, so I figured alright get an alignment and have the check engine light scanned.
First thing was the driver's side rear lower control arm was bent, I thought ok happened from the tow. The check engine light was the Cam Angle Sensor, this one worried me but figured ok it can be fixed. Fast foward to tonight, the mechanic calls me and says the cam angle sensor is in, but the car threw out a Spark code. I've searched for awhile now and haven't been able to find anything about it. Tomorrow the head mechanic is going to be looking at it, so this may be fixed easily but I have no idea. Any one have this happen to them or have any clues to give me to pass onto my mechanic, as always thank you for any help you guys can give me.
Heres the car's spec in case I forgot to put it in my signature.
95 Eagle Talon TSI AWD Turbo 5 speed Manual
Ogami
03-25-2005, 04:29 PM
Figured it out. When he put the timing belt back on, the cam wasn't aligned properly, he took it off redid and the car is fine.
