P1400?
3000GT4ME
03-22-2005, 12:33 PM
my check engine light came on today so i went to autozone and had them test it.. they came up with a P1400 code. i called the dealership and they wont tell me really. they just say to bring it in. I have learned my lesson from that! no way i am doing that.. has anyone else had this problem?? it something with emissions. any help would be great, can i fix it myself?
thanks
ryan
talskinyguy
03-22-2005, 12:43 PM
mitsu diagnostic codes are gennerally 2 digits if i remember correctly. ask autozone what it is
sLADe781
03-22-2005, 01:57 PM
Yeah, when they pull the codes, it should tell you more than just the number. There should be a short description of what the problem is. For example, when I pulled the codes off my sister's Eclipse, it gave me "P0442: Evap-Emissions control system leak (small)" Still not a lot of help but there was a little bit of description.
The1NamedMarc
03-22-2005, 09:00 PM
It's the intake manifold pressure sensor.
http://www.3si.org/forum/showthread.php?t=214921&highlight=p1400
Yes you can fix it yourself. Around $125 part #MD305600
It's located on top left of the plenum held down by two bolts. Look for that part number. It's black lettering, on a little white piece of paper, located on the sensor.
Any other questions?
3000GT4ME
03-23-2005, 12:31 AM
thank you for your help.. any ideas where i can buy the part from? I know nothing about my car as it must sound like, well nothing about fixing it :) the plenum is just under the hood?? easy access? thanks
The1NamedMarc
03-23-2005, 11:18 AM
Yes, very easy access. Here's a picture of the sensor when it is removed. The plenum is the grayish looking thing.
http://www.xtreme2k2.com/upload/uploads/manifold sensor.jpg
To purchase the part, go here.... http://www.mitsupartsdirect.com/
Sign up and let them know you are part of www.3si.org (That gives you a 20% discount)
You can get the part for about $96 instead of $120.
You could also try the dealerships around you but I'm sure they'll charge $125+.
EDIT: Just so you don't worry, I've had the P1400 error for almost a year now. I never felt the need to change the sensor. :p Although, recently, it pulled up another code. 0400 which is the EGR. So I'd say try and get the sensor fixed within a few months or so. It should NOT effect performance. Good luck.
