Help Noise From Front End
duranrp
03-21-2005, 07:13 PM
This noise has been bothering me for a while I can't figure it out at all. Every time I change my oil. I'm always looking for anything out of the ordinary but I can't pinpoint nothing. It only used to happen when I turned my wheels all the way to the left I would hear a knuckling should or you can even feel a thump in the brake pedal when ever I would hold it all the way down when coming to a quick stop, I don't know if that has anything to do with it tough. But now the noise is coming whenever I turn the steering wheel to the left or to the right in quick motions. I don't know what I should look for. I need some insight. thanks for your help pe@ce rich
BullShifter
03-22-2005, 12:39 AM
Ball joints, tie rod ends
Steering rack loose
Raise the car so the front's off the ground
Grab the tire from the top and bottom and push the tire in and out, like your trying to change the camber.
Then do the same by grabbing the tire by the front and rear of tire, do same thing.
You should be able to see something moving if there is a bad joint or loose part.
91civichatch2571
03-22-2005, 06:27 AM
could also be a strut bearing if its none of the above^^
civic_boy91
03-22-2005, 10:10 AM
could be the cv joints.
