convertible problem
iammykehawk
03-20-2005, 10:27 PM
recently its been raining alot in san diego and my camaro is leaking from the side where the window and roof meet, i tried to re adjust the rubber it helped a bit but still leaking what could i do
CamarosRsweet94
03-20-2005, 10:34 PM
Just a blind shot in the dark here; but I recently went to an auto show and there was a car there that had a system in it that would lower the window a tiny bit when you opened the door, then raise it when you closed it. I assume it is intended to help make a better seal with the top to keep water out, so maybe try the same idea, close the door with the window slightly down then raise the window up to meet the rubber. Like I said just a guess but maybe it will prove successful. (Sorry for the long post)
iammykehawk
03-20-2005, 10:54 PM
yea i do that also but still it leaks is there a thing such as a window alignment?
CamarosRsweet94
03-21-2005, 12:06 AM
Not as far as I know. Which way do you mean? Like how far it goes up or how the window is angled left to right in the slides? Also does you window struggle to go up or go up slowly? If so the window lift motor may be going out slowly, that's what happened to mine.
Morley
03-21-2005, 01:36 AM
Yes, there are a multitude of adjustments that can be made to the window to make it seal better/properly.
CamarosRsweet94
03-21-2005, 02:43 AM
Ok, so there is a way to do it... Any help on how Morley?
WannaLearnMore
03-21-2005, 10:32 AM
Most of the time the steps to align/adjust a window is outlined in a Chilton's or Hayne's manual in the section with the window removal/installation. It's not always under that sub-section, but there are steps for it in the book.
CamarosRsweet94
03-22-2005, 12:48 AM
I just checked my Chilton manual and it is clearly described and even has a picture, go buy a manual they are invaluable.
camarodad
04-06-2005, 12:34 PM
If you're going to keep the car for a while then it would be a good bet to spring for a real set of factory manuals. They will cost you more than a Chilton or Haynes but then you will be getting a lot more as well.
Hypsi87
04-06-2005, 12:52 PM
amen revrend
amen revrend
Xenostalgia
04-06-2005, 01:05 PM
Should be sorry, that was a huge post... jk...
Use Duct tape..
If unable to use duct tape, beat with a hammer until Duct Tape will remedy.
Use Duct tape..
R.OConnor
04-07-2005, 12:38 AM
I actually do a lot of work on convertible tops, replace the weather stripping and make sure to install it correctly... it not to hard, just needs to look straight and be for your car
