Door Chime
stu411
03-20-2005, 04:46 PM
What are the possible causes for a 97 Crwn Vic door chime to continue to sound with the key removed? The sound is generally steady but will occasionally not occur or beep eradicately
Thanks
cobradude360
03-20-2005, 05:48 PM
is this with the door open or closed
stu411
03-20-2005, 11:58 PM
door chime sounds with the door open, lights off, & no key in the ignition.....
thank you for any help you can give
way2old
03-21-2005, 06:43 PM
There is a wire on the key cylinder that usually causes this. You can remove key cylinder and disconnect and tape wire or chase down the problem area in the vehicle.
