SWAP Complete
travagliante
03-19-2005, 01:09 PM
Target car: 1990 Honda Civic LX 4 door
Goal: b16a SiR Gen1 Motor
PW0 5spd ecu
Y1 LSD transmission
Parts(besides engine, tranny,etc.)
1.Mounts- I bought AZ race and Machine ones. $200 bucks of ebay, they are like the billet AL. copies of HAsport.
2.Shiftlinkage. Im using modifies 90-93 Integra. Cost: 10bucks vs.110bucks. All i did was cut of about 3in of each rod and bingo!!
3.Drivers side mount bracket and rear mount bracket off a 90-93 teg.
4.Exhaust bolted up fine.
5.New Honda p30 timing belt for a 99si
6. New clutch for a 90 integra
7. 2 gallons of oil (8 quarts, yeah extra)
8. Oil filter
9.Radiator fluid 50/50 mix, 2 gallons
10. 5th gen Slim radiator, Full Alluminum core and tanks
Well i was cheap, didnt want to make or buy an a/c bracket, so i scrapped the air, wasnt cold anyway. Then i looked at the p/s, All i had was a gen 2 p/s pump and crank pulley, and a gen1 alternator and crank pulley. I didnt want to have to get anothe alternator or p/s pump. So... i made a sacrifice and got rid of that also!
Started at about 10am....Yeah i know i skipped school to finish it!
The old engine took a while to get out. I spent like 1hr breaking the fricking ball joints to get the axles out. Had the old motor out by 1pm. Had fun beating the crap out of the rear X-member. These mounts need more clearance than hasports. Put the new one in. I have never put an engine in from the top. Im always a bottom person. It wasnt that bad either. After i got it in i hooked it all up getting ready to test it out. I was just in a hurry to hear it. Plugged in the ECU, and it started right up! Well sorta, It threw like 5 CEL's but it started. I still have to get a new speed sensor, FI o-rings, etc.
Ok are the pictures below.....
These pictures are also kinda old... I took them last night and i did some cleanup on vac lines and wiring this morning.
p/s is pictured but it is gone!
http://img117.exs.cx/img117/4170/azracingmounts6zy.jpg (http://www.imageshack.us)
Look short radiator, hmm wonder why, whats going in the other place?
http://img59.exs.cx/img59/7515/carfront1dx.jpg (http://www.imageshack.us)
Front view w/o radiator
http://img214.exs.cx/img214/7230/civicfrontview3cd.jpg (http://www.imageshack.us)
Yep i got VTECH PHONE inside!
http://img85.exs.cx/img85/8985/dohcvtec7bz.jpg (http://www.imageshack.us)
Tools required: Or mess made!http://img9.exs.cx/img9/3975/partssuppliestools0ge.jpg (http://www.imageshack.us)
and
http://img53.exs.cx/img53/5973/moretoolssupplies2ac.jpg (http://www.imageshack.us)
Currently running a modded 90-91 Teg dizzy, works fine...
http://img59.exs.cx/img59/1642/passsideviewmodded9091dizzy5jx.jpg (http://www.imageshack.us)
Okay i give up, Here is all the room i have when i attempt to turbo another one of my cars again....
http://i146.exs.cx/img146/8910/turbolotsofroom4gj.jpg (http://www.imageshack.us)
And to finish it up. Here is a pic of the 500K vaccum lines that i had to get capped or moved around! oh well you get the idea. BTW they are all cleaned up much nicely now!
http://img8.exs.cx/img8/3914/vaclinessideview9qh.jpg (http://www.imageshack.us)
Thanks for looking.
Andrew
CBURKE
03-19-2005, 01:24 PM
GOOD JOB MAN......
But don't start the motor with that screwdriver in the TB.....j/p good work. feels good uh?
travagliante
03-19-2005, 01:29 PM
LOL i wanted to see how many people noticed that. I put it in there while i was spraying some cleaner to get all of the crap on the TB so it would open easier.
clawhammer
03-19-2005, 01:46 PM
Cool. Have you driven the car yet? Now time to clean up.
Scott82
03-19-2005, 02:04 PM
Looks good i thought about taking off my bumper and everything but i didn't. Looks like it makes things easier to get to so i may have to go ahead and take mine off too. I need to do some brace work to it anyways cause the bumpers a little loose.
BigBearWest
03-19-2005, 04:17 PM
Good job man. How does the new gen rad fit in there? I am thinking if getting so i have room for a turbo
1PhatCX
03-19-2005, 04:36 PM
ditto, i need 2 know too for the same reason :)
also, good job with the swap!
DTangent
03-19-2005, 05:00 PM
Looking good man. Can't wait to try it on mine :) Thanks for the pics.
travagliante
03-19-2005, 08:37 PM
Thanks for the comments.
I had to take the bumper off because my hood latch snapped. Thats why the cable is cut off.
The short radiator. Well the one i got is an aftermarket one. All i have it is placed in there. Im setting it up by cutting a little of the radiator support so i can have it sit up straight, otherwise it would have to set on an angle.
Ill post pics when im done modding the radiator.
No havent drove it yet. I want to get all of the wiring done, cleanup finished, bumper and radiator, and a fan in also. Need to get the drivers axle on. As well as finish exhaust and get a speed sensor.
I was going to get it today but i ficking overslept! So i will have to wait until tuesday to go to the junkyard.
Oh well!
The swap was the easiest i have ever done. Mainly because of that air compressor! Ahh where would i be without it!
