4X4 question
bigry2004
03-18-2005, 01:05 PM
is the front U joint primarily associated with 4 wheel driving? i noticed my front U joints were a little loose today but doesnt look like an immediate task. however, i was under the impression this was only associated with 4 wheel driving, which i rarely use. is this a cause for concern? thanks
BlazerLT
03-18-2005, 03:12 PM
There will be a little bit of play in them.
It is only used for 4wd.
bigry2004
03-18-2005, 11:10 PM
hey, someone else in another forum posted this:
"If your u-joints have any play in them, they're shot. Replace them."
i thought, like you said, a little play was normal.
BlazerLT
03-19-2005, 12:07 AM
You sure it is U-joint play, or the drive shaft itself has play?
blazee
03-19-2005, 07:59 AM
The front driveshaft turns all the time, whether 4wd is engaged or not.
bigry2004
03-19-2005, 04:04 PM
Just the U-joint. Driveshaft feels pretty solid.
BlazerLT
03-19-2005, 04:08 PM
How much play does it have?
smahala1286
03-19-2005, 09:02 PM
we dont have ujoints stock we have crappy cv joints
BlazerLT
03-19-2005, 10:03 PM
The front driveshaft does hae u-joints.
bigry2004
03-20-2005, 12:40 AM
like you can prolly barely jimmy it an inch left and an inch right.. if that.
blazee
03-20-2005, 11:48 AM
He's talking about the front driveshaft, it runs from the transfer case to the front differantial and has U-joints.
You are talking about the front driveaxles, they run from the front differential to the hubs and have CV joints.
blazee
03-20-2005, 11:54 AM
If the U-joints have any slop at all they need to be replaced.
bigry2004
03-20-2005, 03:10 PM
so this goes against the notion that having a little play is alright. and why would they need to be if they're only used in 4X4? not questioning judgement, just curious for knowledge purposes.
blazee
03-20-2005, 03:14 PM
Over all a little play is okay....this is because of the gears, but the u-joints should have zero slop.
They only have a load in 4wd, but they spin (and wear) all the time. If they fail you will be stranded, whether you are in 4wd or not.
bigry2004
03-20-2005, 11:20 PM
alright. thanks, blazee
