Spark BLOW
Stealth-Twinturbo
03-17-2005, 04:25 PM
Does spark blow occur between shifts, because when i shift from first to second it feels like it hesitates for a second. Is that Spark Blow? I don't have my plugs gaped at .034 there at like .040
Igovert500
03-17-2005, 05:47 PM
I would think it would occur more at Wide Open Throttle during 2nd or 3rd gear pulls...when you are at full boost...not while shifting
Perhaps your clutch is slipping... (it tends to start happening around the level of mods you have in your sig)
Twizted_3KGT
03-17-2005, 06:32 PM
I'm not sure what spark blow is, is it when the spark plug doesn't fire b/c it is overloaded w/ air/fuel?
zWhid
03-17-2005, 06:46 PM
even on a newer clutch? cause I think stealth tt just got a new clutch and rebuilt trans
Igovert500
03-17-2005, 07:54 PM
If it wasn't installed correctly yes...
And even if it was, if it was only a stock replacement it is still possible, as they aren't meant to handle 400hp.
Stealth-Twinturbo
03-17-2005, 08:16 PM
It was an Exedy clutch kit like 20% stonger than stock.
