clutch master cyl
kelly190
03-16-2005, 06:01 PM
has anyone changed there clutch master cylinder
it doesnt look like you have enough room to get it
out even if your lucky enough to reach the bolts
any advice
thanks
Twizted_3KGT
03-16-2005, 11:27 PM
Yeah i've done it, had to do it when I converted from automatic to manual 5-speed. And you're right, that was about the most annoying part of the entire conversion was getting that thing to fit in there. I had to move the brake booster/master cylinder over (it wouldn't come out for anything) and tightening the bolt that holds the resevoir on was a pain too. But as far as the bolts that hold it to the firewall, they're on the inside and easy to get to with the right sockets. But it's definitely a tight squeeze even with the brake booster/master cylinder moved way outta the way.
kelly190
03-18-2005, 05:59 PM
Thanks thats what I was afraid of it looks rough
but here goes nothing
Twizted_3KGT
03-19-2005, 09:24 AM
Well just know it's possible to do-it-yourself and good luck!
