electrical problems
96tbird96
03-12-2005, 04:11 PM
hi
i have a 96 tbird. The power locks and the automatic trunk release do not work. I checked all the fuses so that is not the problem. I also need to install a new dome light. I really need a wiring diagram. If any one knows a website i could visit to get one, or another way to get one that would be great
flewthecoupe
03-12-2005, 06:43 PM
Chiltons, Mitchell, etc.
97Bird
03-14-2005, 11:18 AM
Did you check the fuses under the dash? On a 97 the trunk release and door locks are on the same 20A circuit breaker. There are two circuit breakers in the Primary Junction Block under the dash along with 17 fuses. The CB's are together in a corner and the one you ned to check is the one closest to the fuses. The other one is for the power windows and is also a 20A breaker so just swap them to see if your trunk or locks work. Hopefully the 96 is the same as a 97!
