305 to 350 Conversion
bobboock
03-12-2005, 02:11 PM
Hi, My 305 in my 79 camaro just crapped out and I'm thinking of replacing it with a crate 350. How much work is this going to take, will a 350 bolt right up to my THM350 transmission, exhaust etc. I'm also going to put a 4 barrel on. Any help you can give, I'd appreciate. I wanna give this goat some kick. Thanks
Rod&Custom
03-12-2005, 08:29 PM
For sure man, it is a drop in, bolt up project. Really shouldn't be any problem. Good luck!
justlearning
03-12-2005, 10:55 PM
should be simple as pull and replace w/ a carb
89IROC&RS
03-14-2005, 08:10 PM
plug and play, and try not to have too much fun with that right foot ;)
cmjrbking123
03-16-2005, 11:24 PM
i had a iroc with the 350 in it and now im getting a 84 z28 can i drop a 350 in it also??.
89IROC&RS
03-17-2005, 01:38 PM
If the 84 is carburated it should be a no brainer, if its computer controlled there will be more details to attend to, but its still very possible. A small block is a small block, youll just have to address the variables that will effect the computer controls if it has them.
cmjrbking123
03-17-2005, 11:23 PM
thanks for the help.
