power to no power
rocnis
03-11-2005, 03:41 PM
86 caprice starts up then when get up to 40mph or so major power loss. Will not start at all. Several hours latter starts right up and same prob happens again. alternator is good batt is good. What is the prob
PeteA216
03-12-2005, 11:02 PM
The car dies at 40mph? I had a similar problem. When i would go the car would be fine until I got to 35-40 mph, then the car would just suddenly bog right down to nearly nothing and usually die, but it always started right back up. It turned out to be my fuel filter. After i changed that everything was good again. Your problem sounds a little different though, however it does sound something related to fuel delivery, but i wouldn't rule out an electrical problem. Check your fuel pump, lines, filter. Also check all your spark plug wires, ignition coil/connections, and get you spark control module checked out (or check it yourself).
dolluper
03-13-2005, 09:41 AM
You might what to check your fuseible link at starter solinod where it joins the wire they corroate there causes interminite problems seen it many times[head scratcher]
