Please Help
BornInAFord
03-09-2005, 11:55 PM
http://www.automotiveforums.com/vbulletin/showthread.php?p=2880829&goto=2880829
This is a link to my other post about a Van that has a 2.45 draw from the battery when the Van is off. I have pin pointed it to the top connector on the alternator. When disconnected the draw basically disappears.
How do you fix this though? It would seen that you replace the alternator. However I do not want to do this and find out it is the voltage regulator. This is on a 1989 E-250 351 c.i. with 76,000
UnexplodedCow
03-29-2005, 11:40 PM
Is the voltage regulator integrated on the alternator? If it is, then just swap it out. Do you have a manual with schematics in it?
