Oil leak!
ladybird
03-07-2005, 05:20 PM
Apparently my car is leaking some oil. I was told that a leaky oil pan gasket is a common problem. Is this correct? If so how hard is it to replace myself? Any assistance would be greatly appreciated.
FormulaLT1
03-07-2005, 05:27 PM
What year Bird and which engine?
ladybird
03-07-2005, 06:55 PM
1996 Formula LT1 WS6 same car as yours I believe. T-56 if you needed to know.
FormulaLT1
03-07-2005, 07:43 PM
Well first thing to do is to pinpoint were its leaking from and the oil pan is a commen point to leak from although its not unheard of , normally it leaks from the rear main seal and do to clearance issue's its definetly not a easy job.
Josie
03-08-2005, 01:44 PM
...hello, i had a leaking problem not too long ago it was transmission fluid that was leaking. First i thought it was oil but i got it checked out and it wasnt. it was the gasket that was leaking , i didnt do it because of how much it was leaking and it was a total mess underneath the car. So i brought it to a transmission place where they put a new gasket and cleaned it all up and filled it up with new fluid cost me $50 not that much. maybe an idea for you . b/c they only took like 20 minutes to do. ..jus suggesting some things to you maybe they helped
ladybird
03-08-2005, 02:37 PM
I was wondering if anyone knew of any LT1/LS1 performance shops in the Massachusetts/New england area? I want someone working on it that has experience with these cars. A dealer is not really a feasable option because of price. :smokin:
