just did stock de swap
recycle_me
03-07-2005, 01:15 PM
ok i just did a de swap in my 92 240 i bought it with a locked up motor for 50 bucks. everything worked except motor like clutch engaged and gears worked. i just did a swap and got everything back togther and i have no clutch i got paper work on the car it has a new clutch 2 weeks before the motor locked up in it. when i push clutch its like i have no pressure in it. i pulled the motor out of a automatic. everyting is aligned no air in clutch lines. im at a loss. any ideas.
D-Bo
03-07-2005, 01:28 PM
umm maybe you didn't know this but this forum is mainly english.. so try typing in that language.
for your problem, i really don't understand the first part. what i got out of it is you push the clutch down and there's no pressure?? wtf does that mean? if there was no pressure on the clutch, it'd fall to the floor. do you mean when you push the clutch in it doesn't disengage?
Mayday0017
03-07-2005, 02:16 PM
I"m hoping you were smart enough to pull the clutch and flywheel off your blown engine. But if not then that could fix your problem. As you lack the skills to communicate your issue good luck fixing your problem. Oh also check your blinker fluid it could be the problem.
NiSmO_zt
03-07-2005, 07:20 PM
and tighten your muffler bearings while your at it, those are crucial
RACER D12
03-07-2005, 07:55 PM
man its ruff over here in the 240 forum...
D-Bo
03-07-2005, 08:35 PM
hahaha i was gonna say we can be pretty cruel sometimes.. kinda makes me think we drive away too many people
Hit_N_Run-player
03-07-2005, 08:39 PM
not the true 240 owners...
wgfinest3
03-07-2005, 10:42 PM
u guys crack me up...its always good to have a good laugh after a loooong day at work...keep it up lol
wgfinest3
03-07-2005, 10:55 PM
i must say u guys are a lil harsh on us newbs...but 9 times out of 10 u have good reason to cause they ask dumb questions
D-Bo
03-08-2005, 12:31 AM
well what we should be doing is correcting them without being such dicks and helping them but thats not so much fun all the time..
recycle_me
03-08-2005, 03:19 PM
yea you can always tell when mommy bought someones 240 by the way they talk. as for my typing i was in a hurry and just wanted to get the jist in. as for my problem i push clutch in and no pressure is felt. and yes i took the clutch flywheel and all related off the blown motor and put on the good motor. i can put it in first gear and somwtimes it wants to grab but just makes a chirp sound.
D-Bo
03-08-2005, 04:35 PM
recycle_me
03-09-2005, 12:42 PM
why would i need to adjust the pedal hight if it worked fine before i took the trans off? but thinks for trying to help. thats more than i can say for some of the so called experts on this forum. any more info would be great.
D-Bo
03-09-2005, 01:02 PM
ummm because you can adjust how much pressure you're putting into the hydraulic system.. thats what engages and disengages the clutch.. you may not have bled the lines correctly either.. think about that before you post again.
orestes
03-09-2005, 04:34 PM
LOL that was exactly what i was thinking.
recycle_me
03-10-2005, 12:24 PM
umm i never broke the lines to put air in them and the clutch engaged and disengaged fine before i messed with anything. you ppl dont listen on here.
AWDSR20
03-10-2005, 02:21 PM
did u bend the lines? is the clutch new? or in a good condition? take it apart and look at it again...
use a manual, u have the KA motor so unlike us with Sr's u can buy a cheep manual that explain the procedure...
D-Bo
03-10-2005, 03:48 PM
maybe you should try explaining things in english for once
recycle_me
03-11-2005, 01:14 AM
you know something you ppl act like i the only ppl that know anything are you guys. thats why you think that any question a so called newb asks is cracked on when that only thing he is guilty of is coming in contact with you. why cant you ppl just answer a question with out pointing out the way he types or how stupid the question is. because the only thing anyone wants to know is the answer to their question.so F*$k you all that know who you are. and it was the pilot bearing and i said before that it was a BRAND NEW CLUTCH. read the damn posts.
logik23
03-11-2005, 07:57 AM
Is it so hard to capitalize the first letter of a sentence and to put a period at the end of it? It's all we ask, because maybe we could answer the question if we understood what the question was. It takes the same amount of time to type like a normal person and not like Tim when he's drunk.
Tims_240
03-11-2005, 08:21 AM
Damn straight.
LOL
LOL
D-Bo
03-11-2005, 12:06 PM
hahah thats why i don't come on here after the bar anymore..
