HELP! How do you hook up Greddy Profec B spec 2 to Twin Turbo
Stealth-Twinturbo
03-06-2005, 04:42 PM
I just got my Greddy profec B Spec 2 and i want to make sure to hook it up right. How do you hook it up with Twin Acuators? THANKS
Stealth-Twinturbo
03-06-2005, 06:11 PM
Do you just split the like and put a 3 way fitter?
Stealth-Twinturbo
03-07-2005, 04:31 PM
Just disconnect from the stock wastgate solenoid and use the vacum line to the wastegates?
Igovert500
03-08-2005, 12:19 PM
http://www.vr4stealth.com/blitz_dsbc.htm
this is the installation of a blitz ebc, it should help. Also try and make the 2 vacuum tubes from each wastegate equal length.
Stealth-Twinturbo
03-08-2005, 09:07 PM
well with that boost controller all you have to do is take the line off of the Y pipe and reconnect it to the solenoid? Are the blitz and the greddy solenoid relativly the same.
Igovert500
03-08-2005, 11:54 PM
http://www.rtec.ch/dsbc_inst.html
http://www.3si.org/forum/showthread.php?t=224430&highlight=ebc+install
http://www.greddy.com/tech/PROFEC_A_B_HELP.pdf
basically most ebcs are pretty similar
Stealth-Twinturbo
03-09-2005, 07:18 AM
Hey thanks for the help :)
Stealth-Twinturbo
03-11-2005, 08:39 AM
Hooking up this boost controller was so easy. Just plug up the lines and run the lines through the firewall. How easy is that!
