got a problem
G35turbo
03-06-2005, 02:04 PM
ok after i turnd up my boost to 14psi it feels like sometimes the car dosent want to go fast. when mostly at high rpms this happens. it kind feels like its not getting enough fuel to the enigne but my AIR/FUEL gauge shows that i am getting fuel. But when i turn down my psi it dosent do it anymore. could be this a little fuel cut or a boost leak.
THX for the help.
Igovert500
03-06-2005, 02:09 PM
Does it feel like it goes, then slows, then goes, then slows? Kind of like back and forth hesitation...could be spark blowout. Typically fuel cut is a bit more 'violent'. Boost leaks would be less noticeable, you should still pressure test for them though, as they can rob you of power and decrease engine life over time.
G35turbo
03-06-2005, 02:16 PM
ya man thats what it is. it dose what u just said. is it blown or can i sitll gap them???
Igovert500
03-06-2005, 02:53 PM
You can gap them down a bit
you may also want to switch to copper.
G35turbo
03-06-2005, 03:00 PM
ok, thx a lot for the help man.
