O2 Sensors
korndogg
03-05-2005, 11:16 PM
ok i just had my buddy scan my truck and my oxygen sensors are going. should i go with dealer sensors or just get some from somewhere else? im going to do the work myself.
nineball481
03-06-2005, 08:01 AM
I have always used bosch O2 sensors from the autoparts stores. I have never had a problem with them.
pull
03-06-2005, 08:13 AM
what does your truck act like when your sensores are going bad, thanks
nineball481
03-06-2005, 09:09 AM
It just kept poping codes, I don't really know the symptoms that go along with it.
korndogg
03-06-2005, 11:55 AM
yeah theres no symptoms really that you can feel. codes just kept comming up.
and thanks nineball
silveradoking
03-06-2005, 12:01 PM
Bosch sensors are the best...but aren't they pricey also....300-400 canadian for the 4 plugs...
korndogg
03-06-2005, 12:04 PM
the two that i need are $88 american each. should i just go ahead and replace the one after the converter too?? or just wait for that one.
nineball481
03-06-2005, 01:35 PM
I guess it would depend on your funds. also, the old addage "if it's not broke, don't fix it." I probably wouldn't replace them until the computer told me to do so.
korndogg
03-06-2005, 02:41 PM
sounds good
korndogg
03-06-2005, 04:14 PM
ok....i guess my next question is...how hard are they to do on the ground. I do them all the time at work but its up on a lift. am i going to be able to get to them?
nineball481
03-06-2005, 06:27 PM
I can't remember which way they face on the truck, if they point towards the ground or if they are on top, close to the body. Either way you should be able to get to them with out a lift and probably with out a jack. All you will need is an O2 socket and quite possibly a breaker bar. I know the ones I have changed, for the most part, have all been siezed up.
