idleing on boost gauge
viet_boiiiii
03-05-2005, 05:09 PM
Hey all im just wonderin if u guys can tell me whats the normal idleing for the boost gauge. I heard that its suppose to be -20 vaccum when idleing but mines is around -15 vaccum. Can u guys tell your idleing psi and is mines normal?
bighauns
03-05-2005, 06:01 PM
if it is the stock boost gauge, dont even trust it. chances are you are probably fine. the stock gauge is incredibly unreliable.
n8s95gsx
03-05-2005, 06:48 PM
Sounds normal mine is right about at 15 vac.
JoeWagon
03-05-2005, 06:53 PM
You could have searched, but 17 to 20 inches of mercury is normal. Your gauge could be a little off, or your vacuum could be off a little.. either way it doesn't matter. People with cams have 3'' sometimes.
viet_boiiiii
03-05-2005, 06:57 PM
ok thanks u guys. i heard that if u idle lower than 20 vacum than u have a boost leak.
kjewer1
03-05-2005, 11:08 PM
Yes, if you have stock cams and are much below 17-18", it might be worth the time to do a leak test. Low compression can also lower idle vac. My daily driver has two low cylinders (130 psi) but pulls 20" of vac at 1000 rpm idle. I get as low as 10" on the 2g.
97GSTspyder
03-06-2005, 03:01 AM
mine idles at about 16 - 17 at 750rpms, with motor warmed up and no accessorys on. when i have the headlights and heater on, it drops to about 15, sometimes (but rarely) 14. if i raise idle to 1000rpms it stays around 19 - 20.
