96 Cav - starting problems
kelhaley
03-05-2005, 10:13 AM
PLEASE HELP!!
I am having a really hard time starting my car. 96 2.2L.
I have had the fuel pump replaced, plugs, wires, etc.
Yesterday, had my remote starter tested and disconnected - the guys at the shop there ruled out the starter, but disconnected it to see if the car runs better.
The problem is that I have to literally put my foot on the gas pedal to get 'er going. It's not a consistent problem. It has happened when the vehicle is cold or hot. It's just really annoying.
I've tried fuel injector cleaner and had a valve adjusted on the engine.
My mechanic is stumped and I've paid too much to let this one go.
I think it's a fuel injector, but not sure. Any suggestions?
public
03-05-2005, 10:46 AM
You could be right. Could also be a sticky IAC valve. Remove and clean. Also clean the hole where it mounts. Does it run well once started?
kelhaley
03-05-2005, 01:44 PM
Well - the problem is that it's not. It runs okay, but sounding a bit 'loud' for some reason.
Any ideas?
public
03-05-2005, 02:52 PM
you may have a bad leak around your EGR valve. This would cause both problems you describe.
kelhaley
03-05-2005, 04:52 PM
Thanks....I completely appreciate it.
I thought it would be much easier and after spending all this money, now I know where to go with my mechanic. Sux to be a girl and have nobody listen to you.
noshun
Indeed, Exhaust Gas Recirculation valve = pain in the ass! expensive too usually!- sorry! Hey from Whitby ON. only couple hours from yourself there at the falls. If you are a bit of a cavalier enthusiast, check out JCO (J Body Club of Ontario) at www.j-body.com there's planty people in Niagara who will be able to help out, even a good shop that knows cav/fires well. just go into the forum. We're a friendly bunch. Also the canadian J-Body bash is at St Thomas dragway this year! if it's just a car to you some of the locals to you area on there wil still be able to help out!
