85 toyota pickup question
puff3
03-05-2005, 11:12 AM
I just got a 1985 Toyota pickup 2.4L 4speed. So basically im hoping someone could tell me what years engines are compatible, or what other cars I can get parts from. i cant aford a mechanic so it would be nice to know what other cars to look for at pick a part when i gota fix it.
Tim81ta
03-14-2005, 07:03 PM
All 22R engines are compatiable. If up grading to a electronic controlled engine, you would have to install the ECU and wiring harness. I believe from 84 to 88 the body panels are the same.
Tim81ta
03-14-2005, 07:04 PM
randy78
03-16-2005, 10:40 PM
89 was new body i know cuz i scrapped one not too long ago,
87 is old i know cuz i own one
88 i am unsure, it could be either
and 22R is same deal pretty much cept for 22RE and a couple other 22's, all has to do with fuel system
modification_inc
03-17-2005, 11:01 AM
all body parts or the same from 84 to 88 in late 85 they changed the suspention from solid axel to ifs.The 22r engines are pretty much unchanged and should interchange. A good site with alot of info is www.toyotanation.com
Stuck again
03-20-2005, 10:26 AM
Accually there are differences in the 22r engines. Here is a quote from a manual "NOTE : EARLY 81 - 84 22R - RE AND LATE 85 - 95 22R / RE ENGINE BLOCKS / CYLINDER HEADS DO NOT INTERCHANGE WITH-OUT CONSIDERABLE MODIFICATIONS"
Hope that helps
Hope that helps
KimMG
04-01-2005, 02:00 PM
Celicas used 22R engines.
Kyle4130
04-05-2005, 12:48 PM
the truck was actually widened by 3" when they went to IFS in 86. the rear axle is wider.
Furdog
04-12-2005, 10:55 PM
Well not all 22r Motors are....
The 1981-1984 Motors are different the the 1984-1994 22r(e)
You have a 22r a 22re and a 22RET
The ret is a Turbo motor I beleave was in the 1987 Toyota truck.
Even though the 1981-1984 Motor is differnt IT would still work. Keep in mind there is reason for changing the motor.
The heads are diffent sizes so if you pick a 1981-1984 motor good luck finding parts... All you need is a long block from a 1985-1995 - the intake you can add your intake to any 1985-1995 motor. If you have any more (Q's) please fell free to email me and I would be more then happy to help..
DM_Rok
05-25-2005, 02:21 AM
One aditional note:
For high performance applications, you can install a 20R cyl head on a 22R Engine to boost compression.
One aditional note:
