grinding the crank
Red B16A
03-04-2005, 08:18 PM
Is it ok to grind a b16a crank?what should I look out for if anything?
civickiller
03-04-2005, 08:24 PM
take it to a machine shop and see if it can be ground. they should tell you how much they grinded off so you know what bearings you need
Red B16A
03-04-2005, 08:58 PM
On the bearing part, arnt they color coded? So how would I order the bearing in terms of that, stock they were a yellow color. So would I say yellow but 20 over or somthing. Also I heard that the cranks are hardend is that true?
