perfect setup?
94blakGSR
03-03-2005, 05:30 PM
im goin with the jrsc on my gsr if neone knows the perfect setup please help...cams pistons etc. im not looking for nemore then 7 to 9 psi but saftley..and what is the 2.0 stroker kit? thanks
kornflakes28546
03-03-2005, 05:48 PM
if you want some good reliable power, stay with no more than 8psi and get some good FI cams. the cams will make a big difference if tuned right.
SC + cams + Hondata = pretty nice numbers
:smile:
ps - if the JRSC kit doesn't come with a fuel pump or injectors, i would upgrade those too.
*EDIT* 94blakGSR - you have like 4 threads up right now basically about the same thing.
Doubletap
03-03-2005, 05:57 PM
A Stroker kit to my understanding is going to increae the srtoke of the motor with a different crankshaft or something. THis will make the maximum capacity (if all cylinders could be at bottom dead center at the same time 2 liters instead of 1.8. More volume makes more torque but will throw off the rod/srtoke ratio and can make the engine less stable at high RPM... nless somethning has happened to change that since i kast heard.
DoubleTap
94blakGSR
03-03-2005, 07:21 PM
can any mechanics tune the car or where do i have to go
whtteg
03-04-2005, 10:40 PM
Yau can have it tuned at any shop that tunes cars. You will only want to go to shops taht have a dyno and wideband O2.
Stay away form the stroker kit.
And please contain all your questions about the same topic in the same thread.
LOUDCRXSi
03-05-2005, 02:51 PM
what are you plans for the car and how deep are your pockets. the "perfect setup" is gona be deep.
94blakGSR
03-05-2005, 10:10 PM
im not looking for the most power..i wana run the motor moslty stock as i can with 6 to 8 psi saftly..i just wana know the mods that go with the jrsc...loking for mayb 50 to 60 hp gain?
kornflakes28546
03-05-2005, 11:02 PM
7psi will put you over the 50hp mark easy
