heater stuck
rusty4540
03-03-2005, 05:21 PM
My 2000 tahoe gets stuck on high then works fine later on. how can I fix it towork all the time?
themomonga
03-03-2005, 05:43 PM
Replace the acutator under the kick plate on the passengers side. It is the part that opens and closes the door between hot and cold. You can get this from a dealer, or if you can wait a week or so from a site such as www.gmpartsdirect.com. I just replaced mine. The part from gmpartsdirect cost me about $35 with shipping. Look in the Silverado forums for more info. Good luck!
themomonga
03-03-2005, 05:48 PM
oh yeah. You are talking about the HEAT right? If you are talking about the fan, then it is the blower resistor. These were the solutions on my truck and all others I know of anyways.
rusty4540
03-03-2005, 07:08 PM
yes I am talking about my heater, you think the acutator is wearing out and works some times and not sometimes?
themomonga
03-04-2005, 12:51 PM
Most likely. For most people, it will switch over if the heat is not all the way over when you turn your truck on. I could switch from cold to hot, but not back to cold. If this is the case with you I reccomend switching out your actuator. There are a couple other forums about this issue.
http://www.automotiveforums.com/vbulletin/showthread.php?t=342783
http://www.automotiveforums.com/vbulletin/showthread.php?t=294074
Good luck! I hope this helps. Once again I highly reccomend buying this part online as it will save you about $30, looks like this part is $65 at the dealer. Shipping for mine took just over a week. Go to www.gmpartsdirect.com, they had the best price on this item.
rusty4540
03-04-2005, 03:54 PM
thank for your info. I'll try fixing it this weekend.
64Chevy
03-13-2005, 12:07 PM
If you don't want to fix it or don't know how - I have found the following works. Put the heater control to the coldest setting which is like 9 am on the colck. Turn off the car. Turn it back on and do not put the heater dial past 2 pm (if were a clock). 3 pm is the highest setting - never put it to the highest setting and it should work fine.
