Intermittent Charging Alternator; 97 Explorer
JKK
03-02-2005, 07:17 PM
97 Explorer. 4.0L. Automatic. 2WD.
Voltage at battery either 14.1 volts or 12.2 as measured with volt meter. A gentle tap on the alternator usually restores the 14 volt reading. No loose wires.
Are the brushes a potential culprit here? If so, are they easily obtained and replaced ?
If it's not the brushes, is there any other repairable part (regulator?) on these alternators that could cause the problem?
Thanks.
Thanks.
way2old
03-03-2005, 08:10 AM
I think on these alternators everything is internal. If you look at the back of it and see a gray or black square with 4 little screws in it, the regulator is replaceable. If the back is solid, or the wiring connection is inside the case, replace alternator.
