idle adjustment
ziya20
03-01-2005, 03:55 PM
Hello,
Does anybody know how to adjust idle rpm on 4th generatin (1998).
I tried the method from Hynes manual but that did not work.
Should I disconnect TPS cable first?
BP2K2Max
03-01-2005, 08:52 PM
if your car isn't idling properly it's most likely because there is a problem with the vehivle, you pcv valve may be clogged and need replacing, which is very minor, or you could have a vacuum leak, or any other number of things. does the car still drive normally?
