A '92 S-10 Blazer Starting Problem
hoslarson
02-28-2005, 04:05 PM
The specifics:
'92 S-10 Blazer 4x4, 4.3L 6, TBI, 165,000 miles, tuned up not too long ago, smokes some.
The issue:
At random times, usually not hot, cranks but will not start. Normal cranking, plugged in a spare coil, didn't help. Wait a while, starts right up. Will work for a day or so then do the same thing.
A month or two ago, check engine light came on. When codes checked, a Trottle Position Sensor error was in system, when cleared, check engine did not come back on no problems were observed.
The issue:
jsgold
02-28-2005, 04:16 PM
ignition module may be failing. My 93's was just replaced a few months ago for the same reason. Random starting. Got worse very quickly.
BlazerLT
02-28-2005, 04:39 PM
What did the tuneup contain?
hoslarson
02-28-2005, 04:51 PM
Tune up:
Plugs, wires, cap, rotor, fuel filter.
Runs great when it starts, instantly fires if it's going to. Just sometimes doesn't seem to get fire.
BlazerLT
02-28-2005, 07:40 PM
Timing check with the timing wire unattached?
Air filter?
PCV valve?
Clean the EGR valve?
Air filter?
PCV valve?
hoslarson
02-28-2005, 09:35 PM
I think so.
Air filter?
Yes
PCV valve?
Yes
No, it wasn't too bad
I think so.
Air filter?
Yes
PCV valve?
Yes
BlazerLT
02-28-2005, 10:29 PM
You think the timing has been checked or you know?
hoslarson
02-28-2005, 11:51 PM
The timing is good
The timing is good
BlazerLT
03-01-2005, 12:12 AM
The timing is good
What is it set to?
What is it set to?
hoslarson
03-02-2005, 01:20 PM
Good call, changed the ignition module last night and so far so good. It hasn't acted up yet.
